Author Topic: Symptoms of a fuel pump on the way out?  (Read 10574 times)
Offline YGspider
  • The Turbo Geek
  • 87 Turbo T
« on: October 03 2013, 05:45:57 PM »
Knock ? Cant get full RPMS? shuddering under WOT?
Sorry if this has been asked but my search button doesn't seem to work. :icon_redface:
« Last Edit: October 03 2013, 06:18:48 PM by YGspider »
Stratman: Is it even running?
Re: Symptoms of a fuel pump on the way out?
« Reply #1 on: October 03 2013, 07:18:24 PM »
Read Steve's site vortex buicks
« Reply #2 on: October 03 2013, 08:09:43 PM »
Still can't get any RPM's after changing the valve springs?
Offline Super Gnat
« Reply #3 on: October 03 2013, 11:32:42 PM »
I experienced some shuddering under WOT and putting a new adjustable fuel pressure regulator cleared it up. I think the cause was bigger injectors, a hot wire kit, and a new chip. I'm assuming the stock regulator couldn't keep up. I'm pretty new to these cars and by no means is this your issue but thought I would share what i experienced.
Offline YGspider
  • The Turbo Geek
  • 87 Turbo T
« Reply #4 on: October 04 2013, 05:30:49 PM »
I have not got the chance to do anything yet working 7 days a week currently. This question is more for all turbo Buick owners and my own curiosity.
