Author Topic: GN powered sandrail  (Read 2727 times)
Offline trashmechlv
GN powered sandrail
« on: September 29 2013, 02:25:08 PM »
Saw this Turbo V6 powered sandrail at the car show. Sand National.
Mike G
Re: GN powered sandrail
« Reply #1 on: September 29 2013, 02:34:29 PM »
Sand and Turbo's- what could go wrong  :)
Offline trashmechlv
« Reply #2 on: September 29 2013, 03:29:59 PM »
A lot of sand cars are turbo powered, subaru and VW aircooled turbo engines. This is the first Buick powered one Ive seen. I use to go to the dunes quite often riding a KX250 and yes the sand gets in Everything!!
Mike G
« Reply #3 on: September 29 2013, 04:26:19 PM »
He's a member over at TB.com and the original engine was a draw through design. :rock:  He went with SFI so he could do a few things different as far as options. :O
« Reply #4 on: September 30 2013, 06:09:06 PM »
Pretty cool.
