vacuum block
Topic: vacuum block (Read 3157 times)
Shimy87
PSI: 2
vacuum block
September 18 2013, 02:23:48 PM »
During my latest problem solving session I discovered another potential issue. It appears I have a slight leak in or around the vacuum block? I cant see any obvious issue but if I hold my hand over it the slight hissing I hear is muffled. It appears that the plastic block may have a slight bow in it??? Maybe its leaking at the seal to the TB because of this. Anyone run into this before?
phil_long
F47
...far from avg
Re: vacuum block
September 18 2013, 03:38:34 PM »
the piece sitting under vacuum block is cracked...
im still scooting around, although that will be my next investment
Shimy87
PSI: 2
Re: vacuum block
September 18 2013, 03:43:45 PM »
the gasket??
Re: vacuum block
September 18 2013, 04:46:48 PM »
sounds like the gasket to me...
is it snugged down properly?
Spray a little carb cleaner around it and see if the idle changes.
Take it off, put a thin smear of rtv on the base, clean off the top of the plenum, wait 20 minutes, and then bolt it down
Shimy87
PSI: 2
Re: vacuum block
September 18 2013, 04:56:09 PM »
Thanks, i'll give it a try
earlbrown
PSI: 6
Re: vacuum block
Reply #5 on:
September 18 2013, 08:32:27 PM »
Years ago I chased that link and couldn't get it to seal to save my life. I finally got an alum block and solved the problem.
Shimy87
PSI: 2
Re: vacuum block
Reply #6 on:
September 19 2013, 05:03:52 PM »
I saw those but hope I dont have to spend the $40
Shimy87
PSI: 2
Re: vacuum block
Reply #7 on:
September 19 2013, 08:00:19 PM »
Well $40 spent, was going to replace the little hose pieces when I did this and of course the frickin plastic nipple broke off on the end one
Its how it always goes with this dam car!
earlbrown
PSI: 6
Re: vacuum block
Reply #8 on:
September 20 2013, 01:07:13 PM »
I didn't want to spend the money either... The car kinda insisted!
On the upside that's a part that is a permanent fix.
vacuum block
