The Bastard Child Buick Board
Quote from: Shimy87 on September 17 2013, 03:06:40 PMJust came in from a test spin, 21 LBS with controller maxed out. Stupid question time. I think the controller just has a spring with a ball in one end inside. How do I shim the spring? This is what you are dealing with http://www.gusmahon.org/html/boostcontrol.htmtake it apart and put a washer on the end of the spring to increase the tension when assembled. Remember that boost has to flow thru it so make sure the shim has a hole in the middle (washer)
