Do you have a full list of modifications?
Quote from: motorhead on September 14 2013, 04:50:02 PMDo you have a full list of modifications?My sig info, stock unopened engine. 100k miles. Doesn't smoke or use oil (just leaks it). 28" tall tire. Would the speedo being off 8-10 mph from the rear tire cause an issue with the TT chip? I just ran car with a fuel psi gauge and pressure rising consistant with boost. I have boost at 21 and chip overall fuel at 127 now. Fuel psi at idle with vac line on is 38. made 2 pulls on street thru 1st into 2nd gear, O2 on scanmaster 789 and 770 no knock. I stalled car on the brake to 3000 after driving and my O2s were all over the place, jumping from 800 to 560 to 750 constantly random numbers. I never notice O2s doing that when Im making a WOT run.
I don't know what rpms were. Wish I had checked because that had popped into my head today. My shift light is set at 4900 so I can see it flash quickly before my trans shifts as I leave it in drive. I know the light doesn't flash thru the traps so its def under 4900.
