Author Topic: The great wall of 4200-4500 rpm  (Read 12059 times)
Offline dyermullet
Re: The great wall of 4200-4500 rpm
« Reply #30 on: September 15 2013, 05:33:44 PM »
the proper way to use seafoam on a turbo buick is
 start the car
let it warm up
throw the seafaom in the trash
drive the car
It is a lot easier and quicker to check for exhaust leaks than to pull the ps manifold for no reason.
Offline PacecarTA
  • im not a newbie
« Reply #31 on: September 15 2013, 06:12:48 PM »
a length of hose held to your ear will find it easier
btw if you can make boost then  even if you have a leak its not affecting performance or have any effect on the Airfuel (or O2 reading)  , may slow spool but once you have your boost doesnt matter
87 GnX'd
87 GN TTop..stock as can b
