Author Topic: Is the oiler cooler needed after fbody rad install?  (Read 2624 times)
Offline YGspider
  • The Turbo Geek
  • 87 Turbo T
« on: September 05 2013, 03:20:13 PM »
Is the oiler cooler needed after Fbody Rad install?
Stratman: Is it even running?
Re: Is the oiler cooler needed after fbody rad install?
« Reply #1 on: September 05 2013, 04:51:46 PM »
No
« Reply #2 on: September 05 2013, 05:39:45 PM »
depends on how hot your oil is.
Offline Grumpy
« Reply #3 on: September 05 2013, 06:59:25 PM »
NO X2  :cheers:
