General
New Member Introductions and Welcomes!
Hello. New member here.
Topic: Hello. New member here. (Read 7379 times)
OhioTurbo6
Newbie
Boost n00b
September 05 2013, 11:26:48 AM »
Hi,
I'll be taking my new combo to the track tonight and see what it's got.
All built/tuned by me
109 + .030 over, TRWs, stock rods, stock crank, ARP bolts/studs, steel main caps, 204/214 cam, stock heads w/mild work, ported intake, 55# injectors, TT chip, 3" DP/46mm WG, stock intercooler, Hooker cat back, 340 pump/HW, LT1 MAF,
GT6776E turbo, 3400 stall, scanmaster & direct scan.
Race Gas, 28x9 slicks, I'm hoping for an 11 second pass.
87 GN
gnonyx
Turbo Street Modified
Boost n00b
Re: Hello. New member here.
September 05 2013, 12:04:27 PM »
Welcome to a great forum, and great members
Good luck on your run post back with results
SuperSix
Administrator
PSI: 235
September 05 2013, 12:23:40 PM »
Welcome!!!
OhioTurbo6
Newbie
Boost n00b
September 05 2013, 12:24:27 PM »
Thanks! I will let yall know how she does!
87 GN
OhioTurbo6
Newbie
Boost n00b
September 06 2013, 11:01:37 AM »
I only made 2 passes
Fuel 110 Turbo Blue
Pass #1
air bags L=11psi R=18psi
Slicks L=13psi R=13psi
1st/2nd Timing - 23.9
3rd Timing 21.9
Launch Boost - 8psi
Run Boost - 23psi
60` - 1.65 *video shows a lot of spinning*
1/8ET - 7.68
1/8MPH - 88.17
1,000`ET - 10.11
1,000`MPH - 100.47
1/4ET - 12.17
1/4MPH - 109.04
**820mv - Zero KR** - 83.9% Inj DC
Pass #2
1st/2nd Timing - 24.9
3rd Timing 22.3
Launch Boost - 10psi
Run Boost - 25psi
60` - 1.69 *video shows more spinning than before*
1/8ET - 7.76
1/8MPH - 87.63
1,000`ET - 10.20
1,000`MPH - 99.76
1/4ET - 12.28
1/4MPH - 108.46
**800mv - Zero KR** - 83.0% Inj DC
87 GN
SuperSix
Administrator
PSI: 235
Reply #5 on:
September 06 2013, 12:31:54 PM »
Nice!
Good job posting the data too, that will help others with the info.
granitestategn
Turbo Street Limited
Reply #6 on:
September 06 2013, 03:00:06 PM »
Welcome! Sounds like you have the parts you need for the 11 second slip, might just need some tuning. Stock intercooler might be a little bit of a bottleneck but I would think you should still be capable. If you have the clearance, you might try letting a little air out of the bags. Might hook better? With a better 60 ft you should be there or close. My car is slow but there's some other guys here who may have some good input.
12.98 @ 104
OhioTurbo6
Newbie
Boost n00b
Reply #7 on:
September 06 2013, 04:11:28 PM »
Thanks guys! I'm using the ancient Direct Scan. Can't give it up, lol
The intercooler is the only thing that is different from my last build. I had a PTE FMIC several years back and the car went 11.50s on 25# boost.
87 GN
Top Speed
Don't Tread on Me
PSI: -2
Reply #8 on:
September 09 2013, 10:13:39 AM »
Welcome to the board!!!
Champion Irons w/T&D roller rockers, TA-61 turbo, 206/206 Comp Cam, 57 lb/hr Siemens Injectors, 3000 stall PTC, PTE Plenum w/RJC Power Plate, 70 mm Accufab Throttle Body, RJC 325 Megacooler, TurboTweak 5.7/ Alky Control w/M1 methanol, 23 psig on the street, Puddn' Power engine, Borla Exhaust
OhioTurbo6
Newbie
Boost n00b
Reply #9 on:
September 09 2013, 10:17:40 AM »
Thanks!
87 GN
General
