just for the heck of it...look at the top of your pump. Next to the connectors, there should be a couple of metal contacts. I think they are test points or maybe just the attachment rivets for the terminals. touch power and ground wires to those points next to the appropriate +/- terminals. See if the pump then works
Quote from: Joel Russo on September 04 2013, 01:05:42 PMSteve... Do you recommend I replace the in tank wiring? This Walbro came with the wire that plugs into the pump and goes to the hangar.I would....these harnesses are really old and the ground side has always been weakRacetronix sells an hd harnesses that replaces the bulkhead connector in the sending unit and runs the ground wire all the way to the connector so you have a direct ground path. Be sure you tug gently on the wires to make sure they were well crimped in the bulkhead connector
did not bother to contact them because they build perfect stuff
Update: I put the Walbro pump on the bench and hit it with 12 volts. It made a sick sounding humming noise. I then hit the two points that Steve mentioned and it made a similiar humm noise. I then hit the stock pump with 12 volts and it sounded like it was ready to take off. Sounded like a normal pump should. Looks like the Walbro died a premature death, then caused the fuse in the Hotwire harness to blow. Looking on the bright side of things, at least it $hit the bed in my driveway
Quote from: Steve Wood on September 04 2013, 07:11:18 PMdid not bother to contact them because they build perfect stuffSarcasm?
(And you can say "shit" whenever you want to here )Thanks for all the help guys, diagnosing this shit is a pain without the experience of those on here.
Quote from: motorhead on September 04 2013, 09:47:04 PMQuote from: Steve Wood on September 04 2013, 07:11:18 PMdid not bother to contact them because they build perfect stuffSarcasm? Absolutely!The product is great...just the execution of assembly was bad in my case...but I will check it the next time instead of trusting
disconnect the rubber hose that goes from the tank steel tubing to the steel fuel line that goes to the front of the carjump the pump and see if fuel spurts out as it should if the pump is working
