That's a couple hundred pounds, tops. You aren't even close to a "shit-tonne".Step up your game, son.
Speed Inc ftw I've got their SI5 in my bird. For an old grind with old lobes it does pretty well I'd run no less than 3600 stall behind a stock LS1 - let alone a cammed one
Cats are only going to kill a few ponies Mike.When it comes to fbody's the biggest issue is the y-pipe.I've ran over 130mph in the 1/4 with cheap ebay longtubes (which are comparable to the speed engineering pieces) going through a non smooth 3" to 3" y-pipe - it's closer to a T that an Y.There is a pile of hp in the y-pipe I just haven't been able to weld much the last couple years.If you want to take the next step - vband the cats so you can swap them out for test pipes
