Author Topic: The All About My 1980 Pontiac LeMans Station Wagon Thread...  (Read 165858 times)
« Reply #480 on: May 06 2017, 09:52:56 PM »
Aligned the car today.  Boy is the stock stuff limited in its adjustability range.  Best I could get was 3.5* caster, -1.25* camber, and 0 toe.  Garbage!
Bled the brakes again... so many bubbles.
Oh, and I would say that the SFCs I built are doing their job stiffening up the car.
« Reply #481 on: May 06 2017, 09:58:10 PM »
Man I like them wheels!
« Reply #482 on: May 07 2017, 10:30:18 AM »
That looks pretty rigid for a gbody.
« Reply #483 on: May 07 2017, 11:03:40 AM »
I will sell them. ;)
Being a wagon probably helps a lot.  However, the frame is tied together with the SFCs and the body and frame are tied together through the harness bar/weight jacker setup, and I am sure that the monsterous G-Force crossmember is having an effect too.  But, mostly because it is a long roof car. ;)
« Reply #484 on: May 07 2017, 01:04:32 PM »
We had a short break in the weather!
So I did a little tuning today and it is going surprisingly well, cold start was good, idle in P/N and Drive was good, putting around the 'hood was good.  Only a few tweaks to the VE table were in order. Hot restart was a little lean so that is probably an OLFA matter.
The steering and suspension feels really tight - but ARGH! - it is rubbing on the fender liners because it doesn't have enough negative camber.  I figure I can fix this with offset shafts shoved in some circle track arms, a stack of shims, and narrower tires (245/45R17 on a 9.5" wheel); or alternatively I can start cutting up my rare LeMans fenderliners (not a fan of that idea).
Appropriately Natasha asked what that was going to cost - I couldn't muster a response and just hung my head in shame.
« Reply #485 on: May 07 2017, 05:27:12 PM »
Sat down with a coffee and Google to do some thinking about those pesky fenderliners.. .
Felt a lot like this:
https://www.youtube.com/watch?v=iSVMW3jZcg4
What about heat to reshape the plastic? Bingo. It is done all the time in the slammed luxury car world.  An hour later I had gained some much needed space.  I won't know how much until the next time I take it for a boot.
« Reply #486 on: May 08 2017, 11:05:38 AM »
If you can't afford a Steinel heat gun HD has a Milwaulkiee / Wagner with LED temps indicators (~$50) that isn't bad.
« Reply #487 on: May 08 2017, 01:25:32 PM »
Natasha's Mastercraft unit worked well enough, and ironically probably kept me from over doing it being underpowered.  That being said it is good enough to heat up press-fit parts to get them to slide on.
If I really need to keep an eye on temps I bust out my Mastercraft laser temp gun.
« Reply #488 on: May 08 2017, 02:55:13 PM »
Mastercraft not being the ski boat but the house brand of CTC. How do we describe Canadian Tire? A combination of Ace hardware and Pep boys or the old Sears automotive and tool sections?
'Course dunno how they would describe Frys to us...
« Reply #489 on: May 09 2017, 07:53:10 AM »
Crappy Tire is my one tier tool level above Princess Auto.  I am not a Pro, just a Joe.  If I did this sort of thing for real I would buy nicer tools.
« Reply #490 on: May 09 2017, 01:48:42 PM »
I have a harbor freight heat gun - and it's pretty nice for $13.99  :O
I wish we had a fry's - there is a microcenter in madison heights (Detroit), it's an interesting place to go. I just wish it was closer.
« Reply #491 on: May 09 2017, 04:54:57 PM »
We have the frys(actually two within an hour drive) and the microcenter place is up near the second frys. I haven't been in the frys lately. I have bought several refurbished items from them. We used to have a CompUSA that had refurbished stuff but they shut that down and I guess it is the tigerdirect.co m on the interwebz. Brick n mortar is as dead as newspapers from what I can see. I can order stuff, I don't need to have them do it and mark it up for me.
« Reply #492 on: May 11 2017, 03:14:19 PM »
This thing is safetied, registered and insured.
Now what am I going to do with my time?
Offline reality
« Reply #493 on: May 11 2017, 04:47:45 PM »
If it's not broke fix it till it is.
« Reply #494 on: May 11 2017, 05:14:24 PM »
Time to start on the monte
