Author Topic: The All About My 1980 Pontiac LeMans Station Wagon Thread...  (Read 491298 times)
« Reply #465 on: May 02 2017, 09:27:59 PM »
Drove it around the block two-footing it the whole way, and washed it in the rain.  Because car guy.
« Reply #466 on: May 02 2017, 09:52:25 PM »
Sweet! Nothing like a little a payoff.
« Reply #467 on: May 02 2017, 10:41:45 PM »
I'm not sure there is something you remember more than the first trip around the block. Even if there are still things to do on the project. I'm in on the car guy wash, except I rarely wash my vehicles. But I'm pretty sure I'm a car guy.
Nice Work!
« Reply #468 on: May 02 2017, 10:58:53 PM »
Thanks guys, it is hard not to get caught up in the moment (like just listening to it idle) after all this time.
« Reply #469 on: May 02 2017, 11:08:54 PM »
If it is running in pretty sure you have made an accomplishment . I'd sit in my lawn chair and soak in the idle . That's what car guys do.
« Reply #470 on: May 03 2017, 07:29:06 AM »
I hear you.  I must have stood in front of it for a good 10 mins just looking.  Yesterday was only the second time I had ever seen it in daylight.
The next step is to convince Natasha to do Power Tour with it.  The funny thing is that she is become very vocal recently about getting back into Auto-X - wants a 3rd Gen Camaro.
« Reply #471 on: May 03 2017, 12:30:41 PM »
You need to cruise around and embarrass a few local kids  :)
« Reply #472 on: May 03 2017, 02:02:28 PM »
I have one near term goal for this car: use it drop my oldest off on her first day of school in September.  Because I want to be "that Dad".
Offline xpander343
« Reply #473 on: May 03 2017, 08:35:24 PM »
Awesome Job Mike!  its been very cool watching you progress on this project.
87 Regal Limited
« Reply #474 on: May 03 2017, 10:34:11 PM »
Thanks, Steve!  It is a little weird not having any major hurdles to overcome with this car (other than tuning and certification/registration).  I might have to slow down a hair over the summer before getting back to wrenching on projects.
« Reply #475 on: May 04 2017, 11:38:49 AM »
Where is the burnout video?
« Reply #476 on: May 04 2017, 12:40:38 PM »
Don't I wish.  I still have to do 500 break-in miles on the S60, each at short distances at a steady 50mph, with complete cool downs in between.  Very annoying.
When I did the 3.08 gear swap in my Buick the break-in was driving it to the track and beating the living shit out it.  But, that was $300, not $3000; and a decade of wisdom gained.
« Reply #477 on: May 04 2017, 12:46:49 PM »
I am a horrible person.
Yesterday I robbed a bunch of rubber parts off of the other cars to continue refreshing the wagon. Many rubber door bumpers were stolen. It is going to be a rainy weekend so I doubt I am going to get to do much tuning - so I will probably just insulate the doors with some more sound deadener.
« Reply #478 on: May 04 2017, 12:49:34 PM »
Yup get them broke in.
« Reply #479 on: May 05 2017, 11:15:56 PM »
Alright here is the solution for the key lock-out (aka NSS)/reverse light issue with using the stock column range rod and the Hooker swap headers.
1. The bracket which mounts on the brake distribution block needs to have the ball socket moved up 1/2". I cut it along the bend and rewelded it - make sure you measure the angle first before cutting;
2. The bracket on the transmission selector switch need to be cut and moved up 1/2". Note you will need a nut that does not have an integrated washer due to the reduced threads to draw down against (and yes, you could weld the brackets together too);
3. The cross shaft which translates the movement from the shifter/transmission selector switch to the column lock-out needs to be straightened and shaped to go over the header. Guess how much clearance you need to add? That's right - 1/2"! I used a vice and a BFH to give it that sweet custom reverse banana bend;
4. The pinch nut which goes to the column rod needs to flipped to the other side of the bracket on the cross shaft. I rounded the edges off of it to reduce the risk of it binding on things; and
5. Lastly, you may find that you want to chop an inch or two off of the cross shaft that inserts into the ball socket. I took close to 2" off and ran a shorter spring. This really aided in assembly with the header in the way. You may also find that you want to chop an inch off of the bottom of the column rod - your results may vary. Measure once, cut once, weld once, measure again, and cut again.
I am running a B&M shifter and a 4L60E which may be wider at the case body location for the transmission selector switch than other GM transmissions.
