Author Topic: The All About My 1980 Pontiac LeMans Station Wagon Thread...  (Read 165874 times)
« Reply #450 on: April 27 2017, 10:41:48 PM »
Decided not to shorten my 4" diameter shaft, and had a 3.5" made instead.  When I did the final assembly of the exhaust the x-pipe needed to be moved back, so gaining some room with suspension droop is going to be advantageous.
Also built an overflow/expansion tank (started running out of space for things) and added a vacuum distribution block for the heater bypass valve (seriously the only reason I need a vacuum source in this car thanks to electronics).
« Reply #451 on: April 28 2017, 09:23:37 AM »
You'll find the 3.5" driveshaft is enough. Be thankful you have so much room under there. The 3.5" shaft in my bird severely limits exhaust room.
« Reply #452 on: April 28 2017, 09:28:54 AM »
I just wanted to take a moment and thank Steve Wood for learning me about the benefits of Teflon paste.  I put that shit on everything with an NPT threaded connection.
« Reply #453 on: April 28 2017, 09:30:21 AM »
You didn't learn that shit 15 years ago when he told me to stop using tape :D
« Reply #454 on: April 28 2017, 09:51:42 AM »
Oh I did, I just couldn't find any until a few years ago.
« Reply #455 on: April 28 2017, 07:15:58 PM »
Rector seal number 5 is good stuff.
« Reply #456 on: April 28 2017, 07:33:27 PM »
I seem to recall that Masters was the only dope approved (locally) for Nat Gas and Propane.
( What do you mean I just can't move this pipe?..)
« Reply #457 on: April 28 2017, 10:03:21 PM »
Looking good Mike! Got a projected test drive date?
« Reply #458 on: April 29 2017, 10:08:18 PM »
Did somebody say propane?! ;)
Thanks Jason... it might move under its own power tomorrow.  I finished up a few minor things thus far this weekend: 3" wheel studs, torquing down the front suspension, heat shielding around the gas tank, more wiring, and finally got the brakes to hold pressure (we'll see how well in the morning).
Other than that I have a few little things left to do; but most important is to fill the differential.
I know I would really like to wash it.
« Reply #459 on: April 30 2017, 11:05:52 PM »
And done!
No, not really.
Today was just a bunch of farting around tying up loose ends... hell I even put the interior back together.  We had snow today, and now lots of rain, so I could not get it outside to dink around with it - or wash it.  More rain tomorrow.
But, for the first time in 3.5 years it is on the ground - and sitting at 25.5" front and 26.5" rear.  Going to need to add a lot of negative camber... probably source some offset cross shafts.
Going to have to do the safety circle jerk in the meantime (lights and stuff) to make sure it is prepped for certification.
« Reply #460 on: May 01 2017, 04:33:07 PM »
Almost there Mike looking Good!  :rock:
« Reply #461 on: May 01 2017, 05:10:34 PM »
Are you sitting behind the wheel making drag race noises?
« Reply #462 on: May 01 2017, 05:30:50 PM »
Crying mostly.  Because I know once this is up and running I have to fix the TBSS next, and then start rebuilding the MCSS.
Offline TWIN86GNS
  • My car is almost ready!!!!
« Reply #463 on: May 01 2017, 05:37:02 PM »
Mike,
Those are just first world problems!!!  :)
The car looks great, you have done an amazing job and should be very proud of yourself!!!
Paul Beal
beal_paul@yahoo.ca
« Reply #464 on: May 01 2017, 08:20:29 PM »
Mike,
Thanks!
Thanks!
