So onto shocks. After a little research it seems to be beneficial to run a digressive shock vs. a linear unit.
An explanation of the differences:
ORW Bilstein Digressive vs. Linear Valvinghttp://www.circletrack.com/techarticles/139_0307_shock_absorber_tech/viewall.htmlI am a big fan of the Bilstein shocks on both my Buick and TBSS, with the latter have over 100K miles on them. The interesting thing is if you go looking for Bilstein shocks for a G-body you get two choices: HD linear and the standard linear shocks (PNs AK1043 & AK1044). However, if you search for a Chevelle/Malibu (aka an A-Body up to MY 1983) you get a much greater selection:
http://cart.bilsteinus.com/pdfs/motorsports.pdf - see pages 8 and 9.
Based on my research it seems that the travel rates sec/in for the AK1043 shocks are 358#/219# (compression over rebound) in the front, and 254#/141# out back; these are designed for an iron block SBC in a typical G-body which has a significant front end weight bias as compared to a wagon which is closer to 50/50 especially with low options and plans for an aluminum small block (like ours here, estimated final weight around 3300lbs). So with that thought in mind I am pretty confident that the AK6565F at 325#/220# and AK5030R at 300#/120# should prove pretty suitable, especially once the back of this wagon is loaded with the family's stuff.
I will need to drop the cantilever mount on the differential about 2-3" to compensate for the suspension drop to keep the shock in the middle of its 7" of travel once the back is lowered. The front end has 2" drop spindles, which I am going to keep despite the errors it introduces into the suspension geometry, in order to run a taller spring and maintain (as close to) the 5" of total suspension travel the shocks are designed for
I figure these, plus some stock style springs (thinking stock GN springs up front and the OPG "OEM rate" 3" lowering springs in the back) and the Hellwig Pro-Touring hollow swaybars should prove a suitable combination. The classic small spring/big bar formula.
Total cost new will be about $1000 taxes in - which is about the cost of just two coil-overs.
