Author Topic: The All About My 1980 Pontiac LeMans Station Wagon Thread...  (Read 165993 times)
0 Members and 17 Guests are viewing this topic.
« Reply #270 on: March 29 2016, 11:01:59 AM »
Oh... and if you ever wanted to know how wiring in the BCM could be beneficial here is a great little article: http://www.fieros.de/en/articles/BCM.html
« Reply #271 on: March 29 2016, 11:02:29 AM »
Duplicate post.
« Last Edit: March 30 2016, 06:44:57 AM by motorhead »
« Reply #272 on: March 29 2016, 11:03:02 AM »
Duplicate post.
« Last Edit: March 30 2016, 06:44:31 AM by motorhead »
« Reply #273 on: March 29 2016, 11:03:35 AM »
Duplicate post.
« Last Edit: March 30 2016, 06:43:03 AM by motorhead »
« Reply #274 on: March 29 2016, 10:47:07 PM »
I've seen your work before... This will all be in some protective loom and somewhat hidden if not seen at all.
That dude who wrote the BCM article is thorough. Holy Cow!  Yep. Still have no desire to do that
« Reply #275 on: March 29 2016, 10:48:28 PM »
« Reply #276 on: March 29 2016, 10:49:44 PM »
« Reply #277 on: March 30 2016, 06:46:01 AM »
Thanks; and evidently the site was acting up for you too.  Duplicate post. Duplicate post. Duplicate post. Duplicate post. Haha...
« Reply #278 on: March 30 2016, 08:21:02 AM »
I didn't realize it till this morning.  Thought it didn't even post at all.  I ain't going back to edit
« Reply #279 on: March 30 2016, 10:44:06 AM »
I am enjoying my much inflated post count too.
« Reply #280 on: April 05 2016, 09:46:30 PM »
Its alive!
Electronically at least. I got the PCM to talk to me, scanned it and wrote to it.  I was making sure that VATS was turned off, had to set it to "P/N" for the neutral safety switch on the shifter, and turned off the "shifter lock" function (just in case).
I also finished extending the wires - so very un-engaging.  Now I just have to finish routing the wires, wire in the Boost-A-Pump/hot wire to the fuel pump, terminate the SpeedHutgauge leads, connect the cruise control and AC wires, securely mount the underhood fuse blocks and the PCM, and finish looming it up. Ugh.
« Reply #281 on: April 07 2016, 09:26:44 PM »
I decided to splurge on something for the wagon: Hooker 1-7/8" LS swap headers... in stainless.
« Reply #282 on: April 07 2016, 11:51:35 PM »
Cool, will they fit the cross member?
Do they come with ball flanges?
« Reply #283 on: April 08 2016, 09:48:36 AM »
Slip fit out of the box, I am probably going to weld on V-bands.  And they work really well with a G-Force cross member: http://ls1tech.com/forums/conversions-hybrids/1733542-new-hooker-g-body-ls-swap-system-preview-34.html#post19206155
I bought these because I want a direct fit header that should support the OEM trans to column linkages.
« Reply #284 on: April 08 2016, 10:12:41 AM »
Those will look really nice in stainless
