Author Topic: The All About My 1980 Pontiac LeMans Station Wagon Thread...  (Read 165909 times)
« Reply #195 on: September 05 2014, 10:04:54 PM »
Thanks gents!
« Reply #196 on: September 06 2014, 03:17:32 PM »
Gauge holder for my MTX-L wideband...
« Reply #197 on: October 19 2014, 11:47:24 AM »
Looks like I found a good deal on an 8.5" posi out of a Turbo Buick... more to follow.
« Reply #198 on: November 09 2014, 11:02:12 AM »
Yup.  I did.
« Reply #199 on: November 16 2014, 03:21:36 PM »
Finally got the shifter mounted painted (about 2 months ago), all assembled and mounted up, and installed yesterday.  Wired up the WB02 too (the loose yellow wire is the lead from the gauge to the HP Tuners interface for datalogging/tuning).  I am pretty pleased with the way this project turned out.  Our 19 month-old daughter was having a blast slapping the shifter between gears: 1-2-1-2-1-2-1... heh.
Offline v6sleeper
  • G-body guru
« Reply #200 on: November 21 2014, 10:52:27 PM »
Dash and gauges look great!!
87 GN- t-netics hpc,custom 3" dp, champion irons,stage 2 trans ,3021 9.5nl,poston headers ,Atr liquid intercooled, Hemco r plenum
87 Turbo T-  Borg warner,aluminum R-heads,husek trans,E85 Gn-ecu td 1.65 ptc 9.5nl
70 sport wagon 455 stage 1,Gessler alum heads
82 olds wagon Lc2 powered-sold
« Reply #201 on: November 22 2014, 09:20:41 AM »
When will the rear end go in? Stock gears? Posi freshen, or going to give it a whirl as is came?
« Reply #202 on: November 22 2014, 10:43:54 AM »
Thanks! I am really looking forward to them being run by something other than my imagination.
« Reply #203 on: November 22 2014, 10:56:18 AM »
I am not sure yet?  If you look closely you can see that it has FUBAR tooth on the ring gear and rust from sitting.  I still have to price out a set of 3.73 gears, a full rebuild kit (and possible some new posi clutches), and a set of axles; and if that number (plus the aggravation of doing the work) is greater than or near equal too the cost of buying an S60 I will go that route instead.  Black Friday sales on S60s are on now.
« Reply #204 on: November 22 2014, 09:32:30 PM »
The quotes on the S60s are coming in... it is very tempting.
I also pulled off the majority of the front suspension today for modification, and to start chopping up the K-member/engine cradle to fit the LS motor.
And... from talking to Natasha we may just end up boosting a stockish LS motor vice building a more "rowdy" LS1. Uh-oh.
« Reply #205 on: November 27 2014, 09:31:20 AM »
S60,  hadn't thought about that route....
« Reply #206 on: November 27 2014, 02:19:40 PM »
How much power do you intend to make? Slicks? Lots of track? Hard street miles?
Gears, posi, rebuild could get you to a grand real fast. If it went that way I'd go to 30 spline and get a new posi and axles to go with the new gears, bearings and seals. But if you are going for more than 600hp I think the s60 is money ahead.
« Reply #207 on: November 27 2014, 05:57:26 PM »
http://www.strangeengineering.net/high-performance-street/complete-rear-end-assemblies/s60/s60-rear-end-g-body-trac-lock-35-s-t-axles-coil-spring-mounts.html
Yes, All of that. Remember this thing is being fitted for a 450+hp LS1 plus nitrous; and if I do a turbo 5.3L that is 500-600rwhp all day long.  The fact that this thing is getting that kind of power justifies not sinking good money into an old questionable differential.
« Reply #208 on: November 28 2014, 07:30:02 PM »
I wouldnt call an 8.5 10bolt questionable, but it has its limits. If it were me I wouldnt goof with it at your intended hp level. I also think if you go ls you need 6.0 liters but I'm not bankrolling it either. One of our locals has an orange mustang(nick named orange juice) running one with a n 88 turbo, big front mount and a powerglide running deep in the 5s (eighth mile) while driving it to/from track.
Keep up the good work.
« Reply #209 on: December 23 2014, 10:59:42 PM »
Well the S60 was ordered with 3.73s and LS1 housing ends (for LS1 brakes) in a stock width - we got an amazing deal.  So the 8.5" and 7.625" are up for sale.
In other news we are LS-ready!  10" x 2" oil pan notch is done with two 1" x 1" x 1/8" square tubes stacked; and the A/C compressor notch is about 1.5" deep into the pocket, you can see how much the PS motor mount is modified compared to the DS unit.
« Last Edit: December 24 2014, 11:51:27 AM by motorhead »
