Author Topic: Yet another volt light issue  (Read 4078 times)
Offline bescurred
« on: August 20 2013, 06:52:20 PM »
OK, volt light wasn't working at all so I pulled it apart and fixed the connection.  So the light now works and scan master is showing around 12.8-13.2.  The light looks dimmer than the one above it.  Is that because of the resistor? Or do I have to dig deeper into this?
Re: Yet another volt light issue
« Reply #1 on: August 20 2013, 07:22:50 PM »
It's fine, they are never bright anyway.
« Reply #2 on: August 20 2013, 08:56:13 PM »
so now you need to check the voltage at the alternator and see how it is actually charging
« Reply #3 on: August 20 2013, 09:26:57 PM »
And yes the resistor shunts some current away from the bulb
Offline bescurred
« Reply #4 on: August 20 2013, 10:16:36 PM »
13.8 at the back of the alt!!! I'm GTG!  On to the next problem...I will post that later lol.
« Reply #5 on: August 20 2013, 10:27:51 PM »
I have never seen one with a resistor but I have heard rumors that they are out there-just like Big Foot
Offline bescurred
« Reply #6 on: August 20 2013, 10:41:42 PM »
I can pull it back apart and snap a pic for ya.  I swear there is one down in the little socket that holds the bulb.
« Reply #7 on: August 20 2013, 10:46:45 PM »
No need..I have seen pictures from other cars :)  If the car was charging and the bulb was not lighting up when the key was turned on, then it has to have a resistor.
« Reply #8 on: August 20 2013, 11:18:21 PM »
Dude, Bigfoot is real!
