Author Topic: How to change the starter...without frustration?  (Read 11802 times)
Offline gordyzx9r
  • The Sultan of Swank
« on: February 20 2005, 09:54:05 PM »
Alright, I know where the starter is (which is probably step one).  I can even get all the wires off of it (which is probably step two).  But I can't get to the fucking bolt that sits up above the crossover pipe...WTF?  How do I get to that thing without removing the crossover pipe, I have little to no knock right now and don't want to go screwing up how the exhaust is mounted.  BTW...it's an ATR crossover.  All I want to do is put in a mini-starter...but no, it's never easy.  So I put all the wires back on it...and thankfully it started again (well, it should I guess since it's a perfectly good starter...I just want to mount this nifty new mini-starter).
The alternator was surprisingly simple to change out.  Almost scary, it was so simple...somet hing ain't right...the car is going to explode now isn't it?
Supersix...do I get extra points for posting this here and not in the shoutbox?
Re: How to change the starter...without frustration?
« Reply #1 on: February 21 2005, 12:30:35 AM »
Quote from: "gordyzx9r @ Sun Feb 20, 2005 9:54 pm"
Offline gordyzx9r
« Reply #2 on: February 21 2005, 12:35:52 AM »
Yeah...the crossover is sitting about one and a half inches below the starter bolt which is making it difficult to get a socket and driver on it.  I'm thinking maybe a crows foot or something.  I'll have to check out Sears to see if they have some kind of wonder tool or something.
« Reply #3 on: February 21 2005, 12:47:28 AM »
Maybe a Gearwrench?
I wonder if you will be able to remove the bolt once it's loose given the little clearance you have.
Offline gordyzx9r
« Reply #4 on: February 21 2005, 12:56:51 AM »
I shouldn' have to remove the bolt all the way, just as long as it's out of the nut plate. Once I remove the other bolt I should just be able to reposition the starter a bit and then get the bolt out the rest of the way.  Or something.
« Reply #5 on: February 21 2005, 12:59:14 AM »
Quote from: "gordyzx9r @ Mon Feb 21, 2005 12:56 am"
Offline gordyzx9r
« Reply #6 on: February 21 2005, 01:11:25 AM »
Quote from: "SuperSix @ Mon Feb 21, 2005 12:59 am"
Acetylene torch?
Offline gordyzx9r
« Reply #7 on: February 21 2005, 09:09:09 PM »
The dilemma...
Offline Recklessrob
« Reply #8 on: February 22 2005, 12:12:13 AM »
I used an extension with a universal socket on the end. I't worked fine.
Rob
DCEPTCN
  • Guest
« Reply #9 on: February 22 2005, 01:44:31 PM »
Gordy, FWIW- I've twice had to undertake the unenviable taof changing my starter and -based on my experience- there is no way to avoid Excedrin headache #666. I've both times loosened the crossover and disconnected the trans fluid lines. Have two Ziploc/sandwich bags handy to affix to those lines with a rubber band before you've got tranny fluid all over the damn place. Also- be EXTREMELY cautious that you don't tug on those fusible links......I've been there and that sucks worse than I can describe.
Offline gordyzx9r
« Reply #10 on: February 22 2005, 01:51:09 PM »
Screw it, I'll pay someone to suffer the frustration for me.
DCEPTCN
  • Guest
« Reply #11 on: February 22 2005, 02:05:13 PM »
Quote from: "gordyzx9r @ Tue Feb 22, 2005 11:51 am"
When one can afford it, that's probably the best way to go. As I alluded to above, I messed up one of my fusible links while under there and the cost to have a mechanic fix that was about what I would have payed to just have him change the starter in the first place.
