AlkyControl Alcohol/Methanol injection
Author Topic: serious brake problem !!!!  (Read 4663 times)
Offline we4turbobuick
« on: August 15 2013, 02:33:56 PM »
i was checking my brake system out because my pedal was feeling spongey. so I took out the master cylinder and brake booster. and found out that the brake booster I was broke around the plastic tip where the rod that goes to the brake pedal. when they converted to back in brakes I don't think that they changed the pedal and it broke it because the pedal and booster rod wasnt lined up right. so i need a pedal what cars can i get one from? this is one of the many issues im having!!!    :icon_evil:
Re: serious brake problem !!!!
« Reply #1 on: August 15 2013, 02:40:29 PM »
Any RWD GBody, and there's a thread somewhere, I think you can reposition the pin.
« Reply #2 on: August 15 2013, 03:16:23 PM »
this is the pedal I took off with the vacuum setup......
« Reply #4 on: August 15 2013, 08:19:43 PM »
thanks for the info its getting prepped very soon !!!!!
« Reply #5 on: September 03 2013, 11:28:58 AM »
I just got my brake pedal fixed by relocating the pin for the booster. Im haveing problems putting the one nut on the bolt that holds the brake pedal. Its a tight fit in there...... i might have to drop the steering column!! Is there a guide somewhere on the net that can show me how to drop the steering column down so I could make it easier to put the bolt on. Thanks
« Reply #6 on: September 03 2013, 01:43:13 PM »
two nuts to remove to drop the column down...
« Reply #7 on: September 04 2013, 06:44:46 PM »
You and who else?
 :rofl:
« Reply #8 on: September 04 2013, 08:09:34 PM »
you're not coming over?
« Reply #9 on: September 04 2013, 09:40:06 PM »
Haha..
Wait...  :x
