« on: August 14 2013, 02:37:32 PM »
Was thinking about buying or making one of these. Had car up on lift last night and between the brace that is there now and the trans mounting bar I dont see the point. Granted if that U-joint went it would bang things up there but is that loop really going to do much more than whats already there? The shaft cant fall to the ground with the 2 bars under it.
