Author Topic: BL number  (Read 2594 times)
BL number
« on: August 14 2013, 10:39:37 AM »
I thought this should be 128 while crusing, mine is at 118,119 when driving around 60mph. at idle is 128. default settings on tt alky chip. base setting on translator. What should i check or isnt this a problem?
Thanks!!
Re: BL number
« Reply #1 on: August 14 2013, 10:45:58 AM »
why do I post rants about blm's and no one listens?
It is okay
