Author Topic: GReddy Profec B Spec II Boost Controllers  (Read 16354 times)
« on: August 13 2013, 03:14:11 PM »
Are these good? I am thinking about buying a used one..
http://www.amazon.com/GReddy-15500210-Profec-Boost-Controllers/dp/B000AUMKEY
Re: GReddy Profec B Spec II Boost Controllers
« Reply #1 on: August 13 2013, 05:47:15 PM »
Isn't there something more useful that you could spend the money on?
« Reply #2 on: August 13 2013, 06:40:46 PM »
I have one.  It works well and very repeatable.  It has a nice max boost recall to see what the peak was.
« Reply #3 on: August 14 2013, 07:43:47 AM »
I don't know, that's why I am asking. ;0
I would like to have solid, repeatable boost levels.. Price is 1/2 what I see out there.
« Reply #4 on: August 14 2013, 09:51:51 AM »
My boost levels on my cars do exactly the same every time with homemade grainger valve mbc's.  The factory solenoid provided solid boost control.
I have seen more problems with aftermarket wastegates than the factory, but ymmv :)
I would assume you have PowerLogger on your cars but if not, that would be the much better investment.
« Reply #5 on: August 14 2013, 12:23:43 PM »
Yep - PL and Scanmaster will be installed.
I would like cabin control, and not have to use a compressor valve to do it.
« Reply #6 on: August 14 2013, 12:27:28 PM »
I guess if you want to retune the car ever time you change the boost, that is okay.  Might work better with a closed loop wb, but I won't go that route again on a street car.
I am too lazy, I set the boost and leave it there....been years since I moved it off 26 psi on either car.  I never had the performance I wanted out of the regulator valve styles altho others said they worked well for them.  I could seldom make it hit the boost I wanted but rather jumped all round on both sides of my target
« Reply #7 on: August 14 2013, 06:45:25 PM »
One of the benefits of the GReddy is the ability to adjust the gain so that you can control how quickly the boost comes on.   I tried a variety of manual boost controllers, and in the end, like this one the best.  Of course it is also the one of the most expensive options.
« Reply #8 on: August 14 2013, 07:02:44 PM »
Of course, if you try to change the boost from 20-25, the A/F programmed into the chip will be wrong for one, or the other...
« Reply #9 on: August 14 2013, 07:31:59 PM »
Exactly.  You don't want to change the boost different than what the chip is designed for.
« Reply #10 on: August 14 2013, 08:20:42 PM »
wish I had a car that I had to worry about damping the spool up but I would handle that problem with more traction, I think :D
« Reply #11 on: August 14 2013, 11:38:11 PM »
It's hell having to put up with all those fun filled smokey burnouts and fish tails  :)
