Vortex Buick Bible
Author Topic: Belt Tensioner  (Read 28868 times)
Offline dyermullet
Re: Belt Tensioner
« Reply #75 on: October 20 2014, 12:45:44 PM »
I still have the idea for an adapter and I recently found a shop perfect to make me some prototypes.
Does anyone had an idea for an application to check for a tensioner that is close in size?  I already looked at a 98 vortec Chevy v8.  The length of the arm from fulcrum to pulley is too long.
And I agree the guys who can afford the $300 tensioner is crazy.   I will part out the car and move on before I spent that kind of coin on a tensioner.
Re: Belt Tensioner
« Reply #76 on: October 20 2014, 04:43:57 PM »
You spend that on a maf and translator.
Offline dyermullet
Re: Belt Tensioner
« Reply #77 on: October 20 2014, 08:18:04 PM »
I'm running the stock maf.
Re: Belt Tensioner
« Reply #78 on: October 20 2014, 08:20:32 PM »
Or you can toss the maf and use a SD chip
Offline dyermullet
Re: Belt Tensioner
« Reply #79 on: October 20 2014, 10:04:45 PM »
That is what I plan to do if it ever dies
Re: Belt Tensioner
« Reply #80 on: October 21 2014, 12:50:55 PM »
Re: Belt Tensioner
« Reply #81 on: October 21 2014, 01:22:24 PM »
But you just can't use an SD chip?- a list all the things you need as well?....
Re: Belt Tensioner
« Reply #82 on: October 21 2014, 01:26:51 PM »
Hence me still using the stock maf and probably looking for a good used when it fails.
Offline tb3
Re: Belt Tensioner
« Reply #83 on: October 27 2014, 01:47:37 AM »
isnt the only thing you'd really need for our cars with a speed density chip woud be a map sensor?
yes a wide band would help you tune, but might or not be completely nessecery?
