Author Topic: Power windows help!  (Read 3041 times)
Offline TRICKSIXPA
  • Shiny Parts Addict!
Power windows help!
« on: August 05 2013, 05:39:01 PM »
I swapped the guts out from my old car to my roller doors yesterday. The roller had a manual crank window in it I guess they replaced it before it got painted and never changed back the motor. Anyway few beers later put the electrical stuff all back in. Since my car doesn't have a battery or pretty much anything in it yet. Can I jump the power window motor with a 12vt current and get it to move. It's a brand new regulator/motor too.
Re: Power windows help!
« Reply #1 on: August 05 2013, 05:59:24 PM »
Sure you can, reverse the voltage to change direction. Make sure the motor is not loose, and mounted correctly.
Offline TRICKSIXPA
« Reply #2 on: August 05 2013, 06:49:03 PM »
Wow that was way too easy!! Used my battery charger ran ground to the door frame with and alligator clip wire and ran alligator clip wire from the terminal on the charger. Grounded the charger to the body. Used it in2 volt mode went right up. I clipped the wires to the window switch harness blue and black wires.
Done!
« Reply #3 on: August 05 2013, 08:59:41 PM »
If you are at a boneyard mucking with doors bring along a 12-18 volt drill battery
saw that posted somewhere
« Reply #4 on: August 05 2013, 10:39:08 PM »
Nice.
