Author Topic: maf translatpr settings  (Read 3399 times)
« on: August 04 2013, 08:54:56 PM »
Cant find my directions. Have 3 inch maf with base knob on. Setting 3.  The wot knob is on 5 ( 10% rich)  is that where I want it to be when I start my chip tuning for my alky?    Thanks!!!
Re: maf translatpr settings
« Reply #2 on: August 04 2013, 10:49:13 PM »
No...I would put the settings on the base settings with no fuel added
« Reply #3 on: August 05 2013, 01:12:21 PM »
Thanks guys
« Reply #4 on: August 05 2013, 02:17:16 PM »
Make sure the base fp is right and don't use one of those cheap azz gauges on the fuel rail to do it with, either
« Reply #5 on: August 05 2013, 05:18:29 PM »
Got good gauge on long hose. 42 lbs with hose off right???
« Reply #6 on: August 05 2013, 05:45:28 PM »
43 is the TT suggestion I believe.  That should give you idle 02s around 780-800 when the car has been driven around and the coolant is hot...it will change pretty quickly if you let it idle
