Author Topic: 2 nice complete 87 engine wire harness's  (Read 2461 times)
Offline tb3
« on: July 30 2013, 11:40:59 PM »
I have 2 of these. both are from 87 gn's and in identical shape. Both will also come with the positive cable harness like you see in the pic. The positive cable harness's are both complete, and not burned near the downpipe area. both positive cables have the plastic timing cover alt wire hangar, like you see in the pic.
I have went through every wire and connector on both engine harness's and found no wires that have been cut, and no connectors missing.
both engine harness's will come wih the map sensor/relays installed to the pass side bracket, like you see in the pic.
these are used, but good condition and complete.
These come from 87 gn's, (not 86 or prior with the metal ecm clips).
What you see in the pic is what your getting.
I'd like to get $275 shipped (each), to the lower 48
If they don't sell for awhile, I may lower the price.
Offline tb3
Re: 2 nice complete 87 engine wire harness's
« Reply #1 on: August 01 2013, 10:15:25 AM »
both are sold
