Author Topic: 2 step switch/trigger  (Read 2396 times)
« on: July 24 2013, 03:58:54 PM »
So whats the best way to set up a 2 step?
Wire it into the brake light circuit? (have heard there could be a delay)
A heavy duty pressure switch attached to the brake pedal?
or a pressure switch similar to what is used for roll control on the shifter.
Offline TURBOPOWERED68
  • David
Re: 2 step switch/trigger
« Reply #1 on: July 24 2013, 07:28:15 PM »
i have a switch on the brake pedal
« Reply #2 on: July 25 2013, 12:13:10 PM »
How did you attach the switch to the pedal?
  • David
« Reply #3 on: July 25 2013, 08:31:30 PM »
Drilled a hole on the far left side of the pedal.
