Author Topic: Wide band for street use/tuning?  (Read 10819 times)
Offline tb3
Re: Wide band for street use/tuning?
« Reply #15 on: July 27 2013, 09:04:08 AM »
makes sense to me then!   :cheers:
We need to control each injector seperatly, and have a wide band on each cylinder exhaust port, to get the most out of a wide band?
« Reply #16 on: July 27 2013, 09:24:08 AM »
No....not unless you are a millionaire engine building/tuning company
« Reply #17 on: July 27 2013, 10:35:24 AM »
I wonder how bad these  are - look how cheap the sensor/integrated controller is:
http://14point7.com/
I still think the AFX is the best choice but if one is going the cheap route...
« Reply #18 on: July 27 2013, 10:41:17 AM »
You`ve been hanging out with Norbs.
« Reply #19 on: July 27 2013, 10:59:45 AM »
I think he has been reading too many ads and listening to all the guys that don't know anything about tuning posting that you need one to tune.... :)
IF, you have a chip that can be driven closed loop by a wb, then you might be able to justify having one, but, if you have a street car, don't bet on going any faster.  Also, it only sets the a/f to what you typed in and does not give you the flexibility to vary a/f versus rpm and load.  AND, you still have to determine what is the optimum a/f....and how do you do that?
Just like with a factory narrow band...lean as possible without detonation plus a desired  safety factor.
I think some have been led to believe that there is something magical about a wb and they do not have to know how to tune because it does it for them or they think because Joe runs 10.6-1 and he goes high nines...that is the number they should dial in to run 11.8 times.
I use the SD chips which can be driven by a wb, but after twice having the wb stop working when I was wot, I decided to set the car up and then go open loop so I did not go from a 10.8 to a  14.7 in the blink of my eye.
Then we complicate things by having an alky set up...alky affects the a/f so if you spray twice as much alky with your dual nozzle set up as your buddy with a single nozzle set up, and set your a/f's the same because you believe in magic numbers one of you may have an awakening.  Straight methanol may make the most power at an a/f of 4.2 whereas straight gas may make the most power at 10.6 in blown situations.  So what is the magic number if you are spraying a mix?  (there is something to be said for using lambda)
You still have to tune the car!
« Reply #20 on: July 27 2013, 01:29:20 PM »
Like Steve's saying, a wb really won't help unless you are really pushing the limits of the car. In my case I need 1 because it's a carbed car. I don't have the same control over the tune like an SFI car has and have to physically change jets, hangers, and needles to change the tune. There is also a new controller from J&S electronics that will allow for better control of boost and timing rather than rely on the original system. I found out about just recently and have looked at it seriously. It's similar to a 2 step that some are using but it's for a boosted carb application. :rock:  Full control of timing per lb of boost and individual timing retard for each cylinder along with a knock count for each cylinder so you know which cylinder is getting the lowest advance or retard on the timing. :cheers:
« Reply #21 on: July 27 2013, 01:48:33 PM »
yep, wb's are great for carbed car tuning...Some of the modern cars make it a lot easier with the screw in bleeds and jets.
Offline tb3
« Reply #22 on: July 29 2013, 07:44:30 PM »
makes sense to me then.
Let me just say I have put the wide band on 2 of my cars in the past.  My logic was that being that since the stock O2 sensor is not very accurate for anything other than 14.7:1 afr, ... The wide band makes it alot easier to see where I need to "fill in the gaps", like you mentioned earlier.
I have considered it more or less, a good tuning tool for dummies (something I do qualify for  :rock: )
but I am realising the points you make, Steve.  I have very modest and attainable goals for my 87.  I'm gonna have questions when I install alky, turbo and converter on this one
« Reply #23 on: February 26 2016, 10:16:51 AM »
Just saw this come up in my spammed email from Amazon.  Looks really cool:
http://www.plxdevices.com/Wideband-O2-Touch-Screen-Multi-Guage-p/897346002719.htm
Especially for $188.  I might buy one to try if the Buick sells this weekend because the LC-1 in the car will be gone.
http://www.amazon.com/gp/product/B00U1J1MCK?redirect=true&ref_=pe_344980_169888390_em_1p_14_ti
« Reply #24 on: February 26 2016, 10:55:26 AM »
that's pretty slick!  Price is certainly more affordable these days for what you get
« Reply #25 on: February 26 2016, 12:37:59 PM »
nice find Mike that's very cool
« Reply #26 on: February 26 2016, 02:21:05 PM »
Good price.  I paid $230 for my AFX with the NTK sensor, which I thought was a smoking good deal at the time.  They sure have gone up now! :O
« Reply #27 on: February 26 2016, 04:04:13 PM »
What does it spew out the serial port(s)?
« Reply #28 on: February 26 2016, 04:08:31 PM »
Widebands are nice they provide data - but it's what you do with the data that makes the difference.
« Reply #29 on: February 26 2016, 04:21:06 PM »
I guess the Ballenger Motorsports AFR500 equivalent of the AFX is $350 USD w NKT sensor
http://www.bmotorsports.com/shop/product_info.php/products_id/2337
