Author Topic: HS 1.65s with stock valve covers ?  (Read 3460 times)
Offline grand camino
« on: July 23 2013, 11:10:46 AM »
Just bought a set of HS 1.65's for my stock,fully ported,and clearanced , heads...tech guy at HS said he's 90% sure they will clear v/cover :icon_confused:              hmm...90%,does that mean it will only break 10% of my new rockers?
aka"turbocamino" 87 GN motor,trans,rear,dash. TRW+30,balanced crank and rods,max port irons+intake,cometics,212/212-500,HS1.65,6265JB,alkycontrol,stevemon.62mm T/body,JRacing 044-external,TTchips,60Lb.Motrons,RazorAlky,PTC2800L/U, NGK-PLX,GYear ssDR,3"down and out,Airbags
Re: HS 1.65s with stock valve covers ?
« Reply #1 on: July 23 2013, 11:47:48 AM »
I'm 99% sure you won't even be able to bolt down the valve covers.
  It's not a matter of breaking rockers, it's that the roller rockers are taller than stock rockers and need more room.
The fix is either taller valve covers or valve cover spacers.
Offline PacecarTA
  • im not a newbie
« Reply #2 on: July 23 2013, 11:50:34 AM »
Im 100% sure they wont clear
youll need valve cover spacers ,  RJC ...or ebay has them cheaper
and even with the spacer , if you glue them to head you might even need to run a thick VC gasket
« Last Edit: July 23 2013, 11:55:16 AM by PacecarTA »
87 GnX'd
87 GN TTop..stock as can b
« Reply #3 on: July 23 2013, 12:33:26 PM »
 Thanks guys...i was pretty sure i had read that i would need taller... I read that spacer can/will leak...just redid the engine..spent many $'s....see new sig...whats another 200. for v/covers  :icon_eyes:
« Reply #4 on: July 26 2013, 07:25:45 PM »
Won't fit!  Spacers if done right won't leak, my spacers don't leak.
« Reply #5 on: July 27 2013, 04:03:34 PM »
Just musing out loud- Would two piece valve covers, where the lid is just a flat lid be useful on our cars?
« Reply #6 on: July 28 2013, 09:50:16 AM »
That is actually a good idea.  A two piece where you can seal the bottom and have like an insert slide into the bottom half would be awesome.
« Reply #7 on: July 28 2013, 11:52:31 AM »
Pretty sure there are two piece valve covers available for some cars.  Makes it easy to check valves and such without spilling oil all over the place.  I think the tops are o-ringed.  then you could use spacers on top for additional clearance if required.
Bottoms should be o-ringed as well for a good seal.
« Reply #8 on: July 28 2013, 03:28:18 PM »
Yes, you are right Steve.  The top unscrews and the side skirts stay and the rest stay mounted.  I remember M/T had them for small block Chevy's
