A/C, Heating and Cooling
Office duster/HC152A conversion
Pages:
2
3
Topic: Office duster/HC152A conversion (Read 35152 times)
SuperSix
Administrator
PSI: 235
Re: Office duster/HC152A conversion
Reply #30 on:
August 11 2013, 09:41:41 PM »
Possibly, I don't have one. Buy one and send it to me.
daveismissing
Reply #31 on:
August 11 2013, 09:49:02 PM »
I have one, Sent me a can and I will test it for you.
daveismissing
Reply #32 on:
August 19 2013, 10:49:01 AM »
Just looked at Techspray Duster- it is 1,1,1,2 Tetrafluoroeth
ane aka 134A!
TexasT
Legend in my own mind
PSI: 1
So, This black car is fast?
Reply #33 on:
November 03 2013, 09:43:25 AM »
So, I'm reading the links and have a couple questions.
the guy at the s10 link has ester oil in his list of stuff to get. Is this the same as the pag150?
Does the pag150 with uv already in it have any drawbacks?
http://www.amazon.com/TSI-Supercool-PAG-With-P150-8D/dp/B008PKW97Y/ref=sr_1_10?ie=UTF8&qid=1383488239&sr=8-10&keywords=PAG150
Is a wrecking yard compressor a better idea than a remanned unit? I have heard nothing but bad about re-manufactured compressors and how half or more go bad in a short time.
Thanks.
Reply #34 on:
November 03 2013, 10:43:22 AM »
I would buy a new compressor instead of a rebuilt.
From what little reading I have done, pag will work as long as there is no mineral oil in the system. I don't think they used mineral oil since some time in the '90s. Not sure what new compressors come with but I think ester and pag are compatible but I would double check that with some googling
Charlief1
Just another kinky six
PSI: 2
Reply #35 on:
November 03 2013, 11:48:58 AM »
Most systems use PAG because it doesn't wear out like Ester can. Most compressors are dry even though they use a very small amount of oil to assemble them.
SuperSix
Administrator
PSI: 235
Reply #36 on:
November 04 2013, 10:21:59 AM »
I used PAG150, IIRC
TexasT
PSI: 1
Reply #37 on:
September 26 2015, 11:18:20 AM »
I got the side can tap and the vac pump and gauge setup. Haven't opened them up yet as we have volleyball this am. I have to pick up some more duster cans as the kids took and used the ones I had. I think I can use this duster with the mineral oil. And I can mix the pag150 with the mineral oil in the system. Am I wrong? Steve sez I am above.
What can I do short of pulling it all apart?
I am on a budget and would like to get it up and running but will hold off and get the drier and orifice if we think it is necessary. I want to do it right but with my economically challenged state I am doing it on the cheap. The system is stock. Really. I bought it new and nothing but running the A/c until it didn't blow cold any more. I just left it be as I didn't have the knowledge or tools to do anything.
Thanks for the input. I can start another thread but thought this one being added to was better to keep it together.
daveismissing
Reply #38 on:
September 26 2015, 02:13:06 PM »
I'm told you want to change the orifice if for no other reason than that's where
trash from dead compressors etc will accumulate
TexasT
PSI: 1
Reply #39 on:
September 26 2015, 03:02:22 PM »
I'm not sure it has a dead compressor and was going to pull a vacuum on it and try to fill it with the duster stuff. While in the meantime saving up for the orifice tube and drier. Jason hooked me up with a compressor so if the initial deal doesn't work for long I can swap the compressor and hhe other new stuff on and clean it real good then. Poor plan?
Pages:
2
3
