tt chip setting
2
Topic: tt chip setting (Read 4793 times)
Shimy87
PSI: 2
tt chip setting
June 28 2013, 10:22:05 PM »
Is the timing set at 18 for a chip for 93 octane. I will be tuning for alchy soon and dont know where im starting
Scoobum
Re: tt chip setting
June 28 2013, 10:46:23 PM »
http://www.turbobuick.com/forums/threads/5-7-turbotweak-street-chip-with-alky.397281/#post-3229808
Re: tt chip setting
June 29 2013, 12:29:47 AM »
I think Eric normally writes the timing on the chip tag...if there is any doubt, drop him a note with the chip number and your name so he can look it up...but, pretty sure he uses the same settings on most of the chips he does
If you have powerlogger, you can look at the timing graph and see for yourself
Scoobum
Re: tt chip setting
June 29 2013, 09:22:58 AM »
Erics alky chip WOT default timing is 20.5 degrees on PL.
Re: tt chip setting
June 29 2013, 09:50:18 AM »
pretty sure it is normally 23 in 1/2 and 21 in 3/4 by design but I don't know what the non alky version is...pretty sure a search of his board will give that answer but I would just look on the chip label
and yeah, I think I have seen 20.5 on the pl dump
Scoobum
Re: tt chip setting
Reply #5 on:
June 29 2013, 09:54:14 AM »
Steve, I'm seeing 23 degrees in 1st/2nd on PL with my alky chip. Eric always labels his chips.
daveismissing
Re: tt chip setting
Reply #6 on:
June 29 2013, 10:49:08 AM »
Ive got one here says 20-18deg 16-18psi 93oct
Shimy87
PSI: 2
Re: tt chip setting
Reply #7 on:
July 01 2013, 01:08:04 PM »
from my reading, if I stick with this chip, it sounds like the smart thing to do is leave timing alone, get fuel numbers in the 780 range with boost at my goal setting of 22-23LBS, then move timing toward the 23/21 range watching for knock?
Re: tt chip setting
Reply #8 on:
July 01 2013, 01:29:34 PM »
I might look for a bit lower on the o2s, but it will work
Scoobum
Re: tt chip setting
Reply #9 on:
July 01 2013, 02:25:29 PM »
A chip that's burned for exactly what you wanna do is cheap insurance. Just my 2 cents.
Re: tt chip setting
Reply #10 on:
July 01 2013, 03:14:31 PM »
yep
Shimy87
PSI: 2
Re: tt chip setting
Reply #11 on:
July 03 2013, 01:06:00 PM »
I descided just getting a new alky chip was best idea, as soon as I find out the stall of my converter I can order it. better safe than sorry
Re: tt chip setting
Reply #12 on:
July 03 2013, 03:11:02 PM »
don't think you really need the stall for this purpose, but put the car in drive, foot on the brake, mash down on the gas until the car starts to move in spite of the brakes being on and look at the sm to see what rpm that is..use that for the stall
Shimy87
PSI: 2
Re: tt chip setting
Reply #13 on:
July 03 2013, 03:47:29 PM »
The place that did my tranny rebuild told me its a 2000 stall? That dosent seem correct to me, if i remember right when I test/tune, the car overcomes the brakes about 2700/2800.
Stupid question time. I'm going to check it tonight. You say "mash down on the gas"..... so quickly step into it or ease into it while watching the rpm on the SM. Or dosent it make a difference? Also is it the rpm when " the car actually moves" or when it starts to "lean into the brakes"
Thanks!!
Re: tt chip setting
Reply #14 on:
July 03 2013, 07:01:04 PM »
when it starts to turn the tire against the brakes. I normally ease into it so I don't run over something
2
tt chip setting
