Author Topic: Adjusting windows  (Read 11577 times)
Offline xpander343
Adjusting windows
« on: June 28 2013, 04:25:26 PM »
My car has brand new weather stripping and is a t-top car.   I've recently assembled most of the car and was working on getting the windows to close nice.   With the new weather stripping it seems like the motors aren't strong enough to push the windows up tight against them.
I can adjust them so that when they are up and I close the door they seal, but I refuse to have a stupid window I can't close properly when driving.
When doing the adjusting I had the trickle charger on the battery so I assume it was getting enough voltage.  I also replace the window switches because the chrome was falling off, and they were worn out and loose feeling.
Any suggestions on what I should do?  I have the same issue on both sides.  Is this a not enough power to the motors issue? or I just haven't gotten the windows to the perfect spot yet?
87 Regal Limited
Re: Adjusting windows
« Reply #1 on: June 28 2013, 05:15:23 PM »
Probably a bit of both. Hope they are GM seals, otherwise all bets are off.
(just ask Chris :) )
« Reply #2 on: June 28 2013, 05:16:48 PM »
Quote" Your twenty year old seal with the rip in the middle will seal better that that sof-seal crap" unquote
Offline xpander343
« Reply #3 on: June 28 2013, 05:50:06 PM »
the seals on the T-tops came in gm wrappers.  The ones on the car were gbodyparts aftermarket ones.   They will require some mods to get them to puff out in a few spots.
I guess I'll be spending some more time this weekend adjusting.
87 Regal Limited
« Reply #4 on: June 28 2013, 10:38:15 PM »
Those windows have a gazillion adjustments on them. There's a gentleman in the Toronto Area who's been a glazer for 40 years and worked for Speedy Auto Glass.
Offline xpander343
« Reply #5 on: June 29 2013, 10:36:37 AM »
Sounds like I should just spend more time playing with them.   Oh well, long weekends are there for a reason.
87 Regal Limited
« Reply #6 on: July 01 2013, 01:43:24 PM »
I might have a window adjustment book around here somewhere.. I will check.
Offline xpander343
« Reply #8 on: July 04 2013, 12:45:56 PM »
thanks!
87 Regal Limited
