The Bastard Child Buick Board
you should use an iac driver tester to testif the iac is at 100 try opening the throttle body blade by turning the screw in it should dropand by AF 11 do you mean the maf airflow (AF) on scanmaster or AF as in air fuel ratio if you mean AF as in airflow ..., high idle or bad translator settings will affect the AF reading what was the RPM what MAF sensor and was the translator settings changed for ityou should do a continuity of the wires from the iac connector to the ecm connector (unplug ecm)
