Author Topic: Powermaster pedal vs vacuum brake pedal  (Read 6002 times)
« on: June 22 2013, 09:44:34 PM »
Do I remember correctly that the pivot point on the vacuum pedal is about half an inch above the location for the PM pedal....so that the vacuum pedal gives more leverage?
Offline dpasadena
Re: Powermaster pedal vs vacuum brake pedal
« Reply #1 on: June 23 2013, 12:42:31 AM »
I converted my car to vacuum quite a while ago and remember modifying the powermaster pedal to get it to work. The pivot point for the vacuum is roughly 1/2" or so higher than the powermaster, so you have a good memory
« Reply #2 on: June 23 2013, 10:01:37 AM »
« Reply #4 on: June 23 2013, 11:54:06 PM »
Looks like my memory sux
« Reply #5 on: June 24 2013, 01:10:30 AM »
They say the second thing to go is the mind.....   :D
With the clevis point being higher, does the power master enter the car at more of a downward angle, or does GM just let there be an angle involved ?
« Reply #6 on: June 24 2013, 08:45:30 AM »
IIRC there is an intermediate (angle creating) bracket twix firewall and P-Master
« Reply #7 on: June 24 2013, 10:13:56 AM »
PM does have a bracket, don't recall if it had an angle, or not.   And, they are correct, Earl
