Author Topic: WIX oil filter number???  (Read 3150 times)
« on: June 21 2013, 11:17:25 AM »
Anyone know the number of the big filter quick, I forgot to look before i left home, want to pick one up today.  Thanks!!
Re: WIX oil filter number???
« Reply #1 on: June 21 2013, 01:09:08 PM »
wix 1036 is the same as the napa 1036 which replaces the bigger AC pf52.  This is for the stock threads and not the "biggie" conversion
wix number may be 51036
« Last Edit: June 21 2013, 02:39:19 PM by Steve Wood »
« Reply #2 on: June 22 2013, 05:35:14 AM »
the easiest way to get a filter for stock threads is to say you have a 94 S-10 4.3 VIN W  (I just happened to notice my Blazer uses the 'long' buick filter).
that way you don't confuse the parts men by giving them the actual part number.  Often it really seems to knock them out of their element.
« Reply #3 on: June 24 2013, 02:21:20 PM »
WIX 51258  if you have the biggie adapter.
