Author Topic: Old Skool 327 or 283 For My 80 Camaro  (Read 5086 times)
« on: June 16 2013, 04:00:13 PM »
I can get a 283 or 327 engine...both complete from the grandfather of one of the gentleman I race with. He has a lifetime of SBC and BBC parts...and he`s willing to give me either engine. The 283 has the original Powerpack heads and the 327 has the double hump heads. The car isn`t being raced...just driven normally on weekend or evening cruises of 2 to 4 hours in duration. The car currently has a 350 transmission with 3.08 gears. I have a stock stall convertor and one that stalls between 2200-2600. Which is your favorite engine...and what would you recommend for compression ratio as I need it to run on 94.
Re: Old Skool 327 or 283 For My 80 Camaro
« Reply #1 on: June 16 2013, 05:48:53 PM »
Might as well go 327
« Reply #2 on: June 16 2013, 06:29:20 PM »
Take them both and build a  10,000 rpm 301ci screamer.   327 with a 283 crank and  fuelie heads. I still have a new GM 327- 375hp fuelie solid cam new in the tube.
« Reply #3 on: June 16 2013, 09:22:25 PM »
Ya' kill me Ed. Nice to see ya' post. I'm leaning towards the 327.
« Reply #4 on: June 16 2013, 09:49:59 PM »
or just bore the 383 over 1/8th and that gives 301 as I recall....
Offline tb3
« Reply #5 on: June 17 2013, 01:46:30 PM »
did gm build the 327 built before the 350?
« Reply #6 on: June 17 2013, 03:12:04 PM »
http://en.wikipedia.org/wiki/Chevrolet_small-block_engine
327
Production:     1962–1969
Displacement:     327 cu in (5.4 L)
Power:     235 hp (175 kW)-375 hp (280 kW)
Bore and Stroke:     4.000 in × 3.25 in (101.6 mm × 82.6 mm)
350
Production:     1967–2003
Displacement:     350 cu in (5.7 L)
Power:     145 hp (108 kW)-370 hp (276 kW)
Bore and Stroke:     4.000 in × 3.48 in (101.6 mm × 88.4 mm)
« Reply #7 on: June 17 2013, 10:08:58 PM »
Dave...thanks for the info on the 327. The M.O.E goes by the year of the engine...not the year of the chassis for emissions. The only thing I'm gonna have to run is a PCV valve and the vent from the opposite rocker to the air cleaner.
« Reply #8 on: June 17 2013, 10:16:29 PM »
the 350 hp 327 was a bad boy on the street back in the day
Offline turbobuickltd
« Reply #9 on: June 18 2013, 05:22:43 PM »
Um... nope...
http://www.ene.gov.on.ca/environment/en/category/drive_clean/STDPROD_098041.html
Q: In 2001, the owner of a 1986 GMC  vehicle installed a 1970s motor. What  are the emission requirements?
A: This vehicle must:
  • meet  the visible emission standards
  • meet  the emission standards set for the original motor (1986).
  • have  all emissions control equipment normally included with the replacement motor (1970),  or its equivalent, attached and functioning
« Last Edit: June 18 2013, 07:51:32 PM by turbobuickltd »
1987 Buick Regal Limited Turbo T
1991 Oldsmobile 98 Regency Elite
1992 Cadillac Sedan De Ville
2008 Ford F150 4.6L 2wd 'cause 4wd only gets you stuck further from the road!!!
« Reply #10 on: June 18 2013, 10:04:09 PM »
They go by the serial number stamped on the block. Been there...done that.
