Author Topic: Finally  (Read 8383 times)
Finally
« on: June 13 2013, 07:20:23 PM »
Im going to pick up my car tomorrow from the shop.  I finally got the valve springs installed.  I also bought an adjustable wg that's sitting in the passenger seat, dual fans, and casper's kit for the dual fans also sitting in the backseat.  Back to adjusting and tuning when I get this knock gauge installed.  Keep you guys posted.
Re: Finally
« Reply #1 on: June 13 2013, 07:21:39 PM »
Me and my cousin Charles also got the front and back bumper fillers installed on the car.  Although it needs paint, it looks a lot better than it did when they were missing. :rock:
Re: Finally
« Reply #2 on: June 13 2013, 07:59:22 PM »
'bout time you all got up and did something!
Re: Finally
« Reply #3 on: June 13 2013, 10:44:22 PM »
Lol. Agreed
Re: Finally
« Reply #4 on: June 15 2013, 04:00:44 PM »
So, I installed the Knock gauge correctly.  Still not getting a reading though. I also installed the adjustable WG. The c-clip came off with ease, but I didn't realize that I was going to need a gasket after removing the oil tube from the bottom of the turbo.  I should've planned better.  Now i have to order one b/c no local parts store carry them in stock.  Keep you all posted on my progress.
Offline granitestategn
Re: Finally
« Reply #5 on: June 15 2013, 04:10:21 PM »
Why don't you just make one....it's not that hard. The parts store has gasket material if you don't already have some. BTW, you should always have some.....
12.98 @ 104
Re: Finally
« Reply #6 on: June 15 2013, 04:40:40 PM »
Had no idea about this.  Do I just walk in any Parts store and ask for some gasket material?  I'd prefer that anyway!!!  Thanks a lot
Re: Finally
« Reply #7 on: June 15 2013, 04:49:44 PM »
wondering why you removed the oil drain tube.
Do I understand you don't get any lights for a second or two when you turn the key on? Which knock sensor did you buy?
yes, just ask for gasket material and hope for the best.  Don't get the real thin stuff as it always seemed to leak for me
Re: Finally
« Reply #8 on: June 15 2013, 05:04:29 PM »
Correct, no lights during startup out side of the middle indicating that it's on.  The gauge came from Kirbans Performance, and it does not have a name brand on it.  All the other gauges that came in the "kit" that my wife bought say VDO on them.  My boost gauge is vdo as well.  Is it possible that I ruined the gauge by hooking the power up to a switch before instead of the correct way?  Thanks for inquiring.  Im heading off to the parts store to grab some gasket material.  Car runs great with these valve springs installed
Re: Finally
« Reply #9 on: June 16 2013, 01:09:42 PM »
Got everything bolted back up.  Got the hose from the compressor port running straight to the wastegate.  No chance to drive and check to see what the boost is set at, but its not too much shorter than the stock rod right now.  Keep you all posted.
Re: Finally
« Reply #10 on: June 16 2013, 02:12:08 PM »
Easy Steve...easy. He's been on a whirlwind autograph/question/answer tour of the nations finest bowling ball alleys since his second 300 game.
Re: Finally
« Reply #11 on: June 16 2013, 05:50:08 PM »
 :rock: :cheers:
Re: Finally
« Reply #12 on: June 16 2013, 07:40:59 PM »
Lol!  Thats exactly what's been up.  Hahahaha.  Drove the car today.  Seems to be only making about 9 lbs of boost right now.  Boost comes on a lot quicker than the stock setup though, thats for sure.
Re: Finally
« Reply #13 on: June 16 2013, 09:48:28 PM »
should come up slower if everything was working right...but, now you have to shorten the rod to get the boost up
Re: Finally
« Reply #14 on: June 16 2013, 09:48:46 PM »
and you don't do anything in a whirlwind!
