Author Topic: Hoosier Drag Radials  (Read 2731 times)
« on: June 09 2013, 07:23:14 PM »
Anybody tried 'em? Track tire pressure to try?
Re: Hoosier Drag Radials
« Reply #2 on: June 10 2013, 01:54:51 PM »
Brad, I know a guy or two that use them but they are on heavier cars so I am not sure if the inflation would be meaningful.
If it were me, I would put 14 psi in both of them and do a burn out.  Then look at the stripe and see if it is evenly black all the way across.  If it is, I would call it good and worry about what flavor of sno cone I was going to order at the concession stand.  If not, I would adjust the pressure using the old standard.  Blacker in the middle means too much air pressure and take a pound out.  Blacker on the edges, not enuf pressure and add a pound.
Adjust until the color appears even all the way across and call it good
« Reply #3 on: June 10 2013, 02:14:35 PM »
Thats all I used back in the late 80's when I raced every weekend. They hooked good. I would go over to Niagra Falls & get them almost everytime we went to St Catharines to visit the wife's family.
« Reply #4 on: June 10 2013, 05:35:12 PM »
Will do. The sidewall on these things are Godawful thin. They should hook. Relax Supersix. I only paid two hundred for them.
« Reply #5 on: June 10 2013, 07:59:30 PM »
strictly track only...no street
« Reply #6 on: June 10 2013, 10:32:43 PM »
I run it on the street with the 16" rims and street tires.
