Author Topic: Quick Fuel Pressure Drop  (Read 2348 times)
« on: June 09 2013, 07:16:25 PM »
Got a GN here where the fuel pressure drops to zero almost instantly when you turn the key off. Pump is new from Racetronix. Injectors are 55's...unsure of age. Fire away guys.
« Last Edit: June 09 2013, 07:25:03 PM by Scoobum »
Re: Quick Fuel Pressure Drop
« Reply #1 on: June 09 2013, 07:55:23 PM »
stuck injector, fuel pulsator, leaky hangar fuel pump hose, or leaky check valve in the pump.
« Reply #2 on: June 09 2013, 07:57:46 PM »
Thanks Earl.
« Reply #3 on: June 09 2013, 08:13:21 PM »
http://www.vortexbuicks-etc.com/fuel_pressure_diagnosis.htm
somewhere on my site, there should be a write up describing clamping off the two rubber hoses at the front of the car to isolate the problem but I don't see it...anyway, the trouble tree in the link above tells you what to do
« Last Edit: June 09 2013, 08:32:08 PM by Steve Wood »
