Steve, i have the TT chip for my setup with Alky.. currently running 20lbs.. prob going to 23-25 once i figure out my false knock issue.. Would i need a new chip burned even though i have an Alky one?
As Brad said, fuel/air will be close at whatever boost you gave Eric when you ordered the chip. Eric has a pretty wide range of adjustment on the fuel so it should be okay for the range you are aiming for if you did not give him 25 initially.
Brad also makes a good point. Many of the chips seem to be on the rich side-particularly in first and second. This can really kill the spool up on the turbo. I have seen some real traction problems caused when the chip was dialed down on the fuel side
Personally, I think, on street cars, that there is no need for an in the cockpit control and they can cause more problems than any convenience they might offer. I would spend my money on something more rewarding
Set the boost and leave it alone. You don't have to go full throttle all the time...
