Author Topic: 430 LPH pump?  (Read 3779 times)
430 LPH pump?
« on: June 04 2013, 02:26:34 PM »
Anyone running one of these?  I wonder if you'll need a bigger return line?  Looks like a nice unit.
http://www.racetronix.biz/itemdesc.asp?ic=FPS-G7W416EAN&eq=&Tp=
Re: 430 LPH pump?
« Reply #1 on: June 04 2013, 02:37:09 PM »
details say it must have a larger return line so I am guessing it does!  :)
Question I have is why one would need it unless one is in the nines and is fed up with double pumpers
Re: 430 LPH pump?
« Reply #2 on: June 04 2013, 03:25:05 PM »
That is a pretty sexy solution.  Unfortunately my feedline is -10AN. ;)
Re: 430 LPH pump?
« Reply #3 on: June 04 2013, 03:46:57 PM »
Same reason most of us (in our younger days) purchased certain items that were complete Overkill years ago. It sounded like a good idea at the time!!  :chin:
History will repeat itself & especially when it's Car Guys with extra cash we are talking about! Yes I was one of them, but finally learned after paying my Dues via my wallet!
Oh well, it was a Fun Ride while it lasted!  :rock:
Re: 430 LPH pump?
« Reply #4 on: June 04 2013, 04:26:28 PM »
It's an E85 pump, that is one reason.  I would love to run Ethanol.  Also, some kid's cousin's next door neighbor told me I have a 9 sec car. :icon_lol:
Re: 430 LPH pump?
« Reply #5 on: June 04 2013, 04:38:37 PM »
Every part you add is worth 2 tenths so I should be in the 6's!!!  :rofl:
Re: 430 LPH pump?
« Reply #6 on: June 04 2013, 10:09:42 PM »
That's only if it came out of the Kenne Bell catalog
Re: 430 LPH pump?
« Reply #7 on: June 05 2013, 01:23:26 PM »
Exactly Oldtimer!!  :cheers:
Every part he sold was rated to produce 2 tenths!
PS: Where is the little Steve Wood guy like on TBS??
