Nasty Wendy Isn't
knock gauge install
Topic: knock gauge install (Read 3516 times)
phil_long
F47
...far from avg
knock gauge install
June 03 2013, 11:28:21 AM »
Hey guys, i installed my knock gauge, and Im not getting any lights, but my SM is showing knock. I tapped into the yellow wire with the black stripe. Am i missing something? Im running the power for the backlight off of the same accessory as the boost gauge, which is the gear shifter light. Any thoughts?
phil_long
F47
...far from avg
Re: knock gauge install
June 03 2013, 03:38:31 PM »
guess I should just keep searching...th anks for all the responses.
PacecarTA
Turbo Street Limited
PSI: 2
im not a newbie
June 03 2013, 04:00:32 PM »
you should not power from the gear shifter lamp as that is a lamp source and runs through the dimmer switch so it may not be 12v
also check that you have the right pin at the ecm not just yellow with black stripe but pin B7
Paul Magnabuick.com ..NJ rep
86GN pump gas 93/alky 109, iron heads, stock mains, no girdle 9.72 @139
87 GnX'd
87 GN TTop..stock as can b
PacecarTA
PSI: 2
im not a newbie
June 03 2013, 04:06:32 PM »
i suppose suggesting you read the instructions would be too hard
but here they are anyway
Last Edit: June 03 2013, 04:11:38 PM by PacecarTA
87 GnX'd
June 03 2013, 05:29:07 PM »
Put me on retainer and I will check in every 15 minutes!
phil_long
F47
...far from avg
Reply #5 on:
June 03 2013, 10:35:14 PM »
I read the instructions(but clearly no thorough enough). Figured A B on the knock gauge was nothing more than than the backlight like the boost. Thanks for the help. I'll be sure to only post questions about things that don't come with instructions next time.
Last Edit: June 03 2013, 10:54:05 PM by phil_long
phil_long
F47
...far from avg
Reply #6 on:
June 03 2013, 11:01:00 PM »
BUT, i did see that it wanted a 12 volt source, and when the car is running, its more than 12v if its on that pink/black wire(or somewhere in the fuse block). I suppose it wont hurt it though.
PacecarTA
PSI: 2
im not a newbie
Reply #7 on:
June 03 2013, 11:05:07 PM »
good ground and good 12v (or whatever your battery voltage is ) and you should be good
full scale into red is usually about 4 degree KR
not uncommon to see it light an led or two on a hard shift
87 GnX'd
SuperSix
Administrator
PSI: 234
Reply #8 on:
June 08 2013, 03:12:23 PM »
No replies in four hours!?!?!
DEMAND SATISFACTION!!!
Top Speed
Don't Tread on Me
PSI: -2
Reply #9 on:
June 08 2013, 06:33:41 PM »
Slackers around here!
Champion Irons w/T&D roller rockers, TA-61 turbo, 206/206 Comp Cam, 57 lb/hr Siemens Injectors, 3000 stall PTC, PTE Plenum w/RJC Power Plate, 70 mm Accufab Throttle Body, RJC 325 Megacooler, TurboTweak 5.7/ Alky Control w/M1 methanol, 23 psig on the street, Puddn' Power engine, Borla Exhaust
SuperSix
Administrator
PSI: 234
Reply #10 on:
June 10 2013, 12:30:06 PM »
Quote from: Top Speed on June 08 2013, 06:33:41 PM
I would demand a refund. :p
knock gauge install
