Wo0t! People!
Yep.. This newer version has more features - still deciding which ones I want to use. The Shoutbox is still there, and the Weather module works now.
In your Profile, make sure to put as much info as possible to see all the features. THere's built-in multi-platform instant messaging (still testing), and if you want to see your local weatherforcast, in your profile, look for this:
Weather city code: This is not publically viewable Select city
, and click on "Select City", and then (duh) select the city you live in or nearest to you. Then, after you are logged in, you will have your local weather forecast on the bottom of the main page. You can change the clock in your profile, and much more - take some time to poke around.
Thanks for the support!
Mark
