Author Topic: Alky on the way!  (Read 5643 times)
Re: Alky on the way!
« Reply #15 on: June 14 2013, 12:09:08 PM »
Well I might actually get time to put this in next week!! I have not sent my TT chip in to be re-burned for alky. From what I've seen i think i can install the system using this chip, just make adjustments to it? Would anyone have advise as to where to set the timing and fuel for starters when i start to turn up the boost?  I only have a SM for tuning.
Thanks!!!
« Reply #16 on: June 14 2013, 02:59:33 PM »
it will be a little rich at mid range,, but it will work.
Eric normally sets the timing to 23 in first and second and 21 in third and fourth as I recall
