Welcome to IHADAV8.com!
Alky on the way!
2
Topic: Alky on the way! (Read 5644 times)
Shimy87
PSI: 2
Alky on the way!
May 09 2013, 01:18:34 PM »
Just ordered my kit from Alky Control. I'm so excited to get it I cant stand myself!
TWIN86GNS
My car is almost ready!!!!
Turbo Street Limited
Re: Alky on the way!
May 09 2013, 05:02:17 PM »
Did you also order new rear tires? If not you better, you'll need them.
Paul Beal
beal_paul@yahoo.ca
1986 GN #1, 11.38 @ 120.25 mph with a 1.501 60'
1986 GN #2, 13.25 @ 102.95 mph with a 2.086 60'
May 09 2013, 05:34:12 PM »
Welcome to the 20th century!
Shimy87
PSI: 2
May 10 2013, 11:39:51 PM »
I dont have a racetrack near by, where else do you guys get methanol?
May 11 2013, 01:21:38 AM »
90 miles for the closest place that sells it over the counter for me so I buy it on line most of the time
Scoobum
Reply #5 on:
May 11 2013, 07:40:21 AM »
I buy mine at my local hardware store.
Top Speed
Don't Tread on Me
PSI: -2
Reply #6 on:
May 11 2013, 12:44:10 PM »
Took me a while to find some here, but I found a store that sold race gas that carried VP M1.
Champion Irons w/T&D roller rockers, TA-61 turbo, 206/206 Comp Cam, 57 lb/hr Siemens Injectors, 3000 stall PTC, PTE Plenum w/RJC Power Plate, 70 mm Accufab Throttle Body, RJC 325 Megacooler, TurboTweak 5.7/ Alky Control w/M1 methanol, 23 psig on the street, Puddn' Power engine, Borla Exhaust
TurboCajun
Keith Theriot
Turbo Street Modified
PSI: 1
6 Packed
Reply #7 on:
May 11 2013, 02:16:17 PM »
ATV shops usually carry
Shimy87
PSI: 2
Reply #8 on:
May 15 2013, 11:13:27 AM »
Should I use different plugs with alky? Whats best, and what gap??
Thanks!
Reply #9 on:
May 15 2013, 01:46:03 PM »
given the problems with plug quality these days, I think I would put some NGK Ur-5s in it gapped to 0.032-0.035" and call it good
Shimy87
PSI: 2
Reply #10 on:
May 15 2013, 02:03:54 PM »
Thank you sir!!!
Shimy87
PSI: 2
Reply #11 on:
May 16 2013, 12:17:47 PM »
I dont want the control box out in the open, I was going to fab up a plate and mount it where the ash tray is. Dont look like the cable is long enough, is it just computer cable? if so can I just get get an adapter/coupler and extent it?
blackgn1
Newbie
Reply #12 on:
May 25 2013, 12:07:40 AM »
I would go with a non projected tip plug. I used NGK UR-5's for many years. My Autolite Race plugs look much better when reading them. I run high boost and spray alot of alcohol.(Dual Nozzel)
TAI 61
6.70 @ 105mph in the 1/8
Shane
Grumpy
PSI: 4
Reply #13 on:
May 29 2013, 07:03:57 AM »
UR5's here to.. gapped @ 30. Have em in all my junk
PacecarTA
PSI: 2
im not a newbie
Reply #14 on:
May 29 2013, 07:06:27 PM »
i still run junk on the 86
ac delco r42TS .024 gap
street car, lower hp... i run the r43ts at .30
for track if plans are to turn it up ill throw 42's in
Paul Magnabuick.com ..NJ rep
86GN pump gas 93/alky 109, iron heads, stock mains, no girdle 9.72 @139
87 GnX'd
87 GN TTop..stock as can b
2
Alky on the way!
