Nasty Wendy Isn't
sway bar?
Topic: sway bar? (Read 2568 times)
shmed
Turbo Street Limited
sway bar?
May 02 2013, 06:58:50 PM »
hi fellas im workin on the t an it has aftermarket tubular lower rear control arms. id like to reinstall the rear sway bar but theres no mounting holes for it..
can i just drill a couple hole in the arms?
Re: sway bar?
May 02 2013, 08:25:25 PM »
I think you will need to drill it out and weld a steel tube thru it in order to prevent it from crushing when you tighten the bar down
motorhead
PSI: 4
Re: sway bar?
May 02 2013, 08:45:18 PM »
Get a Hellwig "pro-touring" bar...
http://www.hellwigproducts.com/
P/N 55809
There is no need to modify the LCAs.
Tim Hensley
Turbo Street Modified
Boost n00b
Re: sway bar?
May 04 2013, 12:40:50 PM »
X2
DLS 210-210
Champion irons
sway bar?
