Get it to backfire a few times at the line staging. Backfiring on the limiter? We loosened the convertor and it still pushes before we build any boost.AJ___[/q
I have had more luck with aquarium regulators that I have the compressor style...partic ularly when it came to fine adjustment.The manual boost controllers that are simply the pop off style seem to work better as far as I am concerned when it comes to building boost, but, the real secret is the right converter, getting the A/F right, plus getting the timing turned up a bit in first gear. Tranny brakes help for consistency until they become breaks
messing around is how you learn to go faster.Normally you can run more timing at the strip than you can on the street because the engine is cooler unless you are hot lapping the car.I have found that setting the controller with an air compressor is not always the same as you see when driving it. I think this may be due to the area of the wastegate puck affecting the opening rate so that the output side of the controller is seeing something different. But, it's a good way to get a feel for it as well as getting it close. Linearity seldom exists on the ones I have played with.
