Author Topic: cath can  (Read 6417 times)
Offline Tim Hensley
Re: cath can
« Reply #15 on: April 27 2013, 12:45:33 AM »
I wont have blow by
Do I run the billet breathers and let it ride
DLS 210-210
Champion irons
Re: cath can
« Reply #16 on: April 27 2013, 09:17:02 AM »
you lost me.
Re: cath can
« Reply #17 on: April 27 2013, 09:53:18 AM »
the only reason I can see to use a catch can is to cover up blow by.  It takes a pretty good pump to create a vacuum in the crank case
Catch-can to the inlet side of the turbo w/ a check valve, pcv on another circuit to the same... that is how I've designed it in my MCSS.
« Last Edit: April 27 2013, 01:38:03 PM by motorhead »
Offline Tim Hensley
Re: cath can
« Reply #18 on: April 27 2013, 12:42:03 PM »
I see how I lost you
I just put the PCV in  stock location
Put two billet breathers on the valve cover
Never mind the vacuum leak at cruse  not that bad.
MY BLMs have be +-10 with that set up in the past
Moterhead that is the way I thought I would do it
Thanks for the in put
DLS 210-210
Champion irons
Offline Tim Hensley
Re: cath can
« Reply #19 on: May 12 2013, 01:08:51 PM »
I have a 86 Vette 100% stock ,low miles took it for  Saturday cruse.It was idling about 1100 and hunting,and a noticeable knock@ WFO.
Pulled in and raised the hood found the grommet on the valve cover to the throttle plate  cracked ,
I had a new one put it on and Walla back to normal
? is my Buick has vented valve covers with a vacuum leak all the time and its just fine,dose the TT chip adjust for the leak?
DLS 210-210
Champion irons
