Author Topic: Torque Converter recommendations.  (Read 6384 times)
Offline Super Gnat
« on: April 18 2013, 02:57:40 PM »
I would like to try a new torque converter. I have the stock turbo. The car will chirp the tires going into 2nd gear but i cant get the thing to build boost at the line. Currently, the stall is at like 1600 and a shift kit was installed by the previous owner. Not sure if it is the stock D5 converter. It has some bolt on mods that make it a pretty quick car but has had no major engine work.
What brands and stall speed would you recommend?
Thanks for the input.
Re: Torque Converter recommendations.
« Reply #1 on: April 18 2013, 08:58:09 PM »
that sounds like a converter out of a non turbo drivetrain.
Just buy a 2600-2800 rpm stall converter.  Do not buy one that is rated for 3000 rpm stall as it is not needed plus they are badly inefficient in a 11" converter that slips more than it transfers power.
PTC is known for having well built converters.  2600-2800 will work okay with a stock turbo and is perfect for  something in the range of a 44, or 49 (or whatever the modern equivalents are called)
Offline 1KWIKSIX
« Reply #2 on: April 18 2013, 09:09:33 PM »
Easy to check to verify if you've got the factory D5 convertor..... simply drop the transmission convertor shield / cover and you should see D5-D5-D5-D5-D5 stamped all around the circumference of the convertor..... .if its not there or says D7 you know what you don't have installed.
Offline Super Gnat
« Reply #3 on: April 18 2013, 11:01:08 PM »
cool thanks!
Offline Grumpy
« Reply #4 on: April 21 2013, 08:45:17 AM »
"Pat's" converters work great on a car like yours !!!! :rock: low/mid 11 sec cars on up.
Offline tb3
« Reply #5 on: April 21 2013, 09:06:35 AM »
x2 on the ptc's  :rock:
call him on the phone and talk to him. tell him what you got and what you want and he'll build it for you.
Offline Super Gnat
« Reply #6 on: April 23 2013, 05:57:15 PM »
Spoke with Kenny at PTC. I ordered a 10in 2800 stall.
Thanks for the input guys.
Offline 1KWIKSIX
« Reply #7 on: June 01 2013, 06:47:21 AM »
Hey Super Gnat,
Did you every install the 10" PTC 2800 convertor yet?
Did you keep the lock up feature or go with a non-lock up?
Curious to hear your thoughts on the change over after the install.....yo u know "seat of the pants" impression, etc. etc.
thanks,
dave
