Author Topic: Door locks issue with my buick - Requires a locskmith  (Read 2875 times)
Offline incheyenne
  • Newbie
« on: April 10 2013, 02:35:42 AM »
I have my Buick lacrosse 2005 and i'm having with the door lock of my car , actually the door locks stick in hot weather. The button used to open the door gets stuck in the depressed position and the door cannot be opened from the inside.  therefore i requires a locksmith who would fix this properly anyone have some idea about it then kindly suggest me about it.
Re: Door locks issue with my buick - Requires a locskmith
« Reply #1 on: April 10 2013, 10:34:57 AM »
You sure it does not just need the door panel removed and some WD40 sprayed on the mechanism once it has been cleaned off?
« Reply #2 on: April 10 2013, 01:09:54 PM »
If it's just the electric "button/switch" sticking I would grab one from the parts store. Installation shouldn't be that bad? If the actual mech is sticking then do as Steve suggested.
Offline The Radius Kid
« Reply #3 on: April 11 2013, 08:07:34 PM »
With a car like that,you could try posting here:
http://www.gpona.com/forums/index.php?sid=22741c765567ea55c69857a5a6f4168f
« Reply #4 on: April 11 2013, 08:46:46 PM »
John, Winter must be over if your back!!  :player:
